Golf mk3
hardmonkeys
Hollow knocking
Topic: Hollow knocking (Read 2151 times)
vwscottie
GTI forum regular
Hollow knocking
06 September 2011, 21:40 »
I`m getting what i can best describe is a hollow knocking sound which i only notice when the engines cold. It only happens when i`m pulling away and only last for about a mile or so, Its starting to annoy me now not knowing what it is.
Screech16v
MK3 20vt AGU
Re: Hollow knocking
06 September 2011, 21:46 »
Does it relate to wheel speed or engine, roughly what area of the car?
vwscottie
GTI forum regular
Re: Hollow knocking
06 September 2011, 22:18 »
I`d say it relates to the engine speed and it sounds like its coming from the engine bay
johnnyvr6
Here all the time
golf v6 4motion soon to be 1.8t'd
Re: Hollow knocking
06 September 2011, 22:24 »
knocking normally means the bottom end is on its way out
vwscottie
GTI forum regular
Re: Hollow knocking
06 September 2011, 22:30 »
I could under stand that if it was knocking all the time or getting worse.It just started suddenly about 3 weeks ago but it isn`t getting any worse
Wayne
Sir Postalot
Re: Hollow knocking
06 September 2011, 23:48 »
Get the oil pressure checked but it sounds like a big end bearing problem.
trog_nfs
Re: Hollow knocking
Reply #6 on:
07 September 2011, 10:00 »
If there any play in the power steering pump pulley? in my old car i got a knocking sort of noise at idle, and the bearing in the pump had worn and allowing the pulley to move.
AlexMozza
Here all the time
Re: Hollow knocking
Reply #7 on:
07 September 2011, 15:45 »
Drop the sump and have a look
That was the sound my Celica made when the big ends went
2001 Satria GTi
Mini 25 Special Edition 1984 998
Formula 3 Mechanic
vwscottie
GTI forum regular
Re: Hollow knocking
Reply #8 on:
07 September 2011, 18:29 »
I almost certian its not the bearing i`ve had some go on me before and it sounded differant to this knocking
philmar
Re: Hollow knocking
Reply #9 on:
07 September 2011, 18:42 »
Does it smoke when you first start it? It could be Piston slap or small end bearing wear.
Golf mk3
hardmonkeys
Hollow knocking
