Author Topic: Mystery lead  (Read 2075 times)
Offline samm
Mystery lead
« on: 06 September 2011, 20:48 »
I have found a lead on on my gti cab which comes through the firewall into the engine and  then does not go anywhere.  It seems to be just an empty pipe but with heat flux on the loose end.
Can anyone help identify what this is and where it supposed to go to?
http://img545.imageshack.us/img545/9363/dsc01241d.jpg
http://img64.imageshack.us/img64/140/dsc01242pp.jpg
http://img263.imageshack.us/img263/557/dsc01243x.jpg
http://img703.imageshack.us/img703/3457/dsc01244cs.jpg
its the clear lead with the black flux on the end
any help greatly appreciated.
Offline samm
Re: Mystery lead
« Reply #1 on: 06 September 2011, 20:50 »
http://img850.imageshack.us/img850/1889/dsc01242pointer.jpg
heres one with arrows to make it clearer
cheers
Offline SoundillusioN
Re: Mystery lead
« Reply #2 on: 07 September 2011, 09:30 »
Hi,
That's a Vacuum hose that connects to the back of your clocks in the dash where it will measure the vacuum to produce info like MPG on your MFA Display. It should be connected to the same vac circuit as that yellow one I see in your pic, I don't recognise the yellow one, where does that seem to go?
Offline samm
Re: Mystery lead
« Reply #3 on: 10 September 2011, 12:18 »
Cheers mate that would make sense as there is no mpg readout, i will check the yellow lead on monday when i get the car back as its currently having a service.
