Author Topic: MK2 clutch choice.  (Read 1916 times)
Offline wurth
MK2 clutch choice.
« on: 06 September 2011, 19:21 »
Right so the pedals been getting heavier and heavier, then put foot on clutch the other day it it want bang in first gear.
So box is out and clutch looks ok, cable is also ok, push rod is ok and gear box is ok (i hope) ??
Anyway its a GU 1.8 engine with a GTI box. So which clutch to go for GU or GTI ?
Thankie.
Offline mk2bal
Re: MK2 clutch choice.
« Reply #1 on: 06 September 2011, 20:34 »
The clutch has to suit the box (input shaft). You'll have to confirm its a gti box by the code stamped underneath it, before you order
« Reply #2 on: 06 September 2011, 23:44 »
And try to get Sachs or Luk if you can
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 07 September 2011, 00:25 »
Ditto
Thom
Offline wurth
« Reply #4 on: 12 September 2011, 13:49 »
Yep defo. Box is AUG 050. 1.8 8v (pb) gti right ?
Offline mk2bal
« Reply #5 on: 12 September 2011, 19:56 »
Think that means august the 5th, 1990. That's the date of manufacture. It'll be an 020 or similar box if its a mk2 gti
