Author Topic: bigger engine  (Read 1599 times)
Offline dubslug
bigger engine
« on: 19 April 2005, 18:49 »
i have a digi 8v gti on h plate but want more power(but not a 16v wanna stay 8v)
if i get it rebored to 1900cc wot else will i need??
 pistons or can i just use bigger rings??
anything else??
or i have read that a 2 litre block just bolts on??
is this true??
wot car can i find doner engine in etc etc??
lagain wot will i need to do this conversion??
which is the cheapeat easiest and wot power gains will i see??
cheers all
a very confused rik
1992 pearl grey 8v
Offline Bullitt
Re: bigger engine
« Reply #1 on: 19 April 2005, 20:34 »
Going bigger capacity will only offer minimal power gains unless you have some head work..
1.9 means boring the block and new pistons/rings..
Go for a complete running 2.0 8v from a mk3 golf, early passat with gasflowed head, web camshaft 111 or 125 profile or similar & chipped ecu..
This should give you a very good power increase over your standard GTI!!  :grin:
http://www.webcamshafts.com
Offline ...joe
Re: bigger engine
« Reply #2 on: 19 April 2005, 21:38 »
have a look at my project section as i'm doing something similar at the moment. i was advised against doing a 2ltr conversion for what ever reason so opted for a 1900 re-bore, after i cracked a piston. with this i already had a piper 285 cam and have had my head done to go with this.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
