Author Topic: Radio wiring??????Pls help  (Read 5132 times)
Offline 87_PROJECT
« on: 19 March 2003, 19:51 »
Hey guys...
Im recently got a stereo for my mk2,however i have a problem!!!
How/where the hell can I find out which wire is which...I only actually need to know the power wires...+and-,All the others I can probably figure out from there...
Any help/pointing in the right direction would be appreciated...
I have tried the Haynes manual but the wiring diagram didnt make much sense!!!!!
Many thanks
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline 87_PROJECT
Re: Radio wiring??????Pls help
« Reply #1 on: 19 March 2003, 19:52 »
P.S.
There was no stereo fitted when I got the car....or I would have been able to figure it out from that one!!!:)
mo3000
« Reply #2 on: 19 March 2003, 20:32 »
it depends on year of car, but a good rule of thumb for the power is Brown is negative, and solid red or red with a black trace is live. the blue and white wire is live when the lights are on so if you have a stereo with a display dimmer use this one.
If this is on a Mk2, thats the only power wires you have.
Offline 87_PROJECT
« Reply #3 on: 19 March 2003, 22:08 »
Thanks mate,
I sorted it:) used the old trial and error approach,managed to get it working without blowing the car up so im pleased...just been out for a spin to "test it out":P
Offline mickandsej
;)Re: Radio wiring??????Pls help
« Reply #4 on: 10 May 2003, 16:59 »
Just had to do the same on my '92 8v - Wife's mk3 came without a stereo but with an ISO block, however Halfords list gives 2 options and I now know it needed an adaptor loom as the +ve and switched are crossed over. Same as standard Mk2 (on my '90 Jetta). TOP TIP get down to Halfords NOW as they are clearing out obsolete adaptor looms - normally ?11 for a loose ISO block, how about one for a Daewoo for 60p - just chop off the end and hey presto a cheap ISO connector. If trying to fit an ISO block with just a clutch of loose wires, I don't think you can find a switched feed so do without or tap off the glovebox light, a rule of thumb is all the -ve have brown tracers, and simply look at the back of each speaker for the colour code. Dry run before soldering as you can't easily tell left from right though front and rear will be easy to spot. Better still go for solder and heat shrink sleeving and it will all fit back in without scraping your arm behind the dash.
I have gone for a simple CD tuner and nothing too loud, as the car has the classic digifant knackered idle and I need to listen for running on!
« Last Edit: 01 January 1970, 01:00 by -1 »
