Author Topic: poly bushes/ tracking-camber  (Read 1498 times)
Offline sharki786
  • GOT BOOST??
« on: 03 September 2011, 13:09 »
hi all,
ive ordered some flo-flex poly bushes for the wish bone, as when im crawing (5-10mph) theres a creaking/knocking noise. i just had my tracking done and he checked the camber and said its bang on.
well my question was if i was to replace them poly buses will i need to re-track & camber the car? as i know khare had put his in but didnt say if he had tracked the car.
also is there a guide on how to do the bushes apart from burning them out and pressing the others in?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: poly bushes/ tracking-camber
« Reply #1 on: 03 September 2011, 15:57 »
A full suspension  geometry check should be done after any work carried out on it, especially when changing bushes.
Offline javalin
« Reply #2 on: 05 September 2011, 10:45 »
don't burn them out!! - look here - http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/polybushings/index.htm A hack saw and chisel will do it.
but TBH having done this earlier in the year (and converted back!) - just get new arms with pre-fitted rubber bushes, much easier!  http://www.vwspares.co.uk/product_info.php?products_id=593
Easiest way to do it, is to undo the lower strut mounting (strut->hub) and then push the hub up and tie (zip ties) to the bottom of the strut.  Gives you the access to get the wishbones in easier.
(note there is a left & right part for the GTI, but same part for non GTI - see the pages)
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 06 September 2011, 22:58 »
James
why did you change back? i fitted mine in, was a doddle, smashed out the old ones and pressed the polys in, the ride is ALOT softer but my cousine says that it will get harder after a 100 miles or so.
now im after uprated droplinks and the uprated lower ball joints BUT will these be ok if i changed to the 2.9 vr6 engine???
i fitted flo flex bushes btw
« Last Edit: 06 September 2011, 22:59 by sharki786 »
*****MK4 GTI T*****
« Reply #4 on: 06 September 2011, 23:14 »
Im confused, how can poly bushes be softer than the standard ones and possibly get stiffer with use?   :huh:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 06 September 2011, 23:32 »
the old original bushes were SOLID!!!! no movement on them at all, these bushes can be squeezed to an extent in you hands. but he said the ride will stiffen up :undecided:
but main question is can i get uprated droplinks and uprated ball joints?
*****MK4 GTI T*****
« Reply #6 on: 06 September 2011, 23:51 »
Really, Ive only ever known them to get softer and deteriorate with age and use. Strange.
I'm sure you can get poly drop link bushes but Ive never come across any uprated ball joints as yet, no doubt there are some megabucks rosejointed track items available though.
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 07 September 2011, 00:20 »
think i have confused you guys, it is soft (theres to holes op each other in the rear bush) the car feels soft (not bouncy) and ALOT stiffer :grin: going around the corner
are these the drop link bushes>>>> http://www.floflex.co.uk/product_info.php?cPath=28_126&products_id=596
*****MK4 GTI T*****
