Author Topic: VERY little space behind headunit  (Read 1187 times)
Offline Bellend
« on: 02 September 2011, 22:55 »
Anyone else experiance this?
I had a Kenwood unit where the phono for the sub sticks in the back and there is so little room it has done the cable in a bit. Ran that headunit over accidentally, new headunit, so little space that the wires on the wiring block on the H/U have gone funny so the sub just keeps "poping" and if I wiggle them and twist them they'll come back.
Going to repair that loom, no worries but has anyone come across this before?
Just no space for anything!
Where all my moneys went.
Offline dom
  • Back in a Mk4
Re: VERY little space behind headunit
« Reply #1 on: 02 September 2011, 23:12 »
Take the glove box out & you've got plenty of access :wink:
Offline Bellend
« Reply #2 on: 03 September 2011, 00:07 »
Thanks. :)
Done that it's just the red and white phonos want to hit the heater box all the time.  :undecided:
The headunit doesn't like slotting back in. I've managed to tuck most of the wiring under the headunit.
Offline garfayliu
« Reply #3 on: 03 September 2011, 10:05 »
I run all the wiring into the cavity in between the glove box and the head unit. There is a hole at the back left where everything seems to fit. Perhaps you need shorter phono connectors, if distance from back of head unit to dash plastic surround is a problem.
Offline Bellend
« Reply #4 on: 03 September 2011, 12:09 »
Hmm perhaps cheers mate.
Going to cover the edges of the metal cage with duct tape to stop them being so sharp and get some right angle phonos.
Cheers. :)
Offline Gti Gerbil
« Reply #5 on: 03 September 2011, 12:19 »
you can get 90 degree adaptors for the phono's, that sorted the same problem i had on a previous car
cheap ones
http://cgi.ebay.co.uk/RCA-Single-90-Degree-Coupler-Phono-Adaptor-M-F-Gold-/380141885458
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
