Author Topic: Suspension question for a Mk2 8v  (Read 1332 times)
Offline Big Fat Fish
« on: 19 April 2005, 11:16 »
Right, just getting a '87 8v off a mate on the cheap, but he admits, suspension a bit supect. Done a search, but not quite found the answer.......not looking hard enuf i 'spect
On a bit of a budget, who would recommend what-pls bear in mind car cost me £250, and I cant justify spending that again on the car without worthwhile return in cornering fun!!
Question is I'm gonna replace shocks and springs, what would someone recommend-and putting back to standard is an option!! So would a simple Bilstein Kit do the job for example? or do i go down carparts, and get 4 std springs and dampers?
Also, bushes-I'm thinking of upgrading to poly-is it worth doing, and are the powerflex ones noticeably better than a cheaper set such as a bug pack set in noise department? After all, this is the wife's commuter and this factor needs to be considered.
Fish
Offline Gambit
Re: Suspension question for a Mk2 8v
« Reply #1 on: 19 April 2005, 11:30 »
just get the Bilstein Streetline kit from EuroCarParts & a new front top mounts
i wouldnt worry about polybushes
Offline Organisys
  • Old and Slow...
« Reply #2 on: 19 April 2005, 12:14 »
Agree with Gambit, but do the bump stops as well, as these are likely to be split and soggy.
« Reply #3 on: 19 April 2005, 18:49 »
Cheers fellas, get on to carparts tomoz
