Author Topic: roof aerial seal.  (Read 4503 times)
Offline gasketface
roof aerial seal.
« on: 02 September 2011, 15:02 »
My roof aerial seal is non existent so i took a look on Ebay and found this :-
 http://www.ebay.co.uk/itm/VW-Golf-Mk3-Mk4-Mk-3-4-Roof-Aerial-Antenna-Gasket-Seal-/400234460445?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2fd5351d
In case this link expires the seller is :- http://myworld.ebay.co.uk/car-masts-uk/?_trksid=p4340.l2559
Being a tight**s i thought i'd get one from my local dealer only to find that it's not available as a separate part.Not sure the parts guy really tried so does anyone know if this is available as a single part ?.
Re: roof aerial seal.
« Reply #1 on: 02 September 2011, 21:43 »
That is correct, it is not available without the base from VW, I made my own out a piece of old inner tube.
Offline Youngben8
« Reply #2 on: 03 September 2011, 11:35 »
Yes I spent ages looking for one of these seals as the genuine part from VW is not available so I had to buy the complete aerial base for about £24.00 I wish I had waited now and bought the seal off this ebay seller. :cry:
Offline Dan_GTi8v
« Reply #3 on: 03 September 2011, 14:26 »
whats wrong with the ebay one? I bought one and its perfect
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 03 September 2011, 16:03 »
As above, the fleabay one is fine.
Offline gasketface
« Reply #5 on: 03 September 2011, 16:17 »
I will buy one now.I just hate waiting for things when i can order them from up the road and get them next day. :grin:
Offline kahunajb
« Reply #6 on: 03 September 2011, 16:21 »
The ebay ad says it can normally be fiited from the outside without the need to remove the head lining. Is this true in peoples experience?
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline Seanl
« Reply #7 on: 03 September 2011, 16:26 »
NO!
You will need to take the aerial off, and disconnect the cable to slip the new seal in.
Offline kahunajb
« Reply #8 on: 03 September 2011, 16:34 »
ah. So the headliner and interior trim needs to be removed to get at it. That sounds like a real pain.
Offline Seanl
« Reply #9 on: 03 September 2011, 16:37 »
Just remove the trim running along the top of the boot. You should be able to get in there without bending your headlining too much, and you just need to pull the co-axial connector apart, then undo the securing bolt. Nice and easy!  :smiley:
