Author Topic: Could I still use this link  (Read 2742 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 31 August 2011, 21:50 »
http://www.myturbodiesel.com/1000q/a4/clean-intake-manifold-VW-TDI-carbon.htm
This is from the sticky section, how to. This link says it is not for a PD engine, I have the 150pd and need to clean my EGR and manifold, have searched around and cannot find a dedicated guide on a PD engine. Would I still be able to use this guide? How much difference would there be? Or does anyone now of a guide that I could use?
Cheers, Si
Offline Rhyso
Re: Could I still use this link
« Reply #1 on: 01 September 2011, 09:58 »
Doesn't look too dissimilar to the 150  :undecided:
Offline scarr89
« Reply #2 on: 01 September 2011, 12:27 »
That is what I was thinking. But would it be along similar lines, perhaps a different screw here or there. As long as it should all be the same idea...I need to find a PD guide!
Offline Rhyso
« Reply #3 on: 01 September 2011, 13:12 »
The basics are there for sure  :smiley:  Removing the EGR and air intake is the same process  :smiley:
Offline NoCrap
« Reply #4 on: 02 September 2011, 08:05 »
Yeah looks pretty much identical - its definitely worth getting the inlet off too and giving that a clean but you may wish to consider new bolts and gasket (less than £10 all together from TPS)
