Golf mk3
hardmonkeys
OS Steering Gaitor possible in situ?
Topic: OS Steering Gaitor possible in situ? (Read 1286 times)
bmouthboyo
Here all the time
31 August 2011, 17:28 »
Hi Guys,
I need to replace a split boot / gaitor on my offside.
Is it possible to replace this without having to remove the whole trackrod? Space is very limited and not sure how I could get in my cv clip pliers to secure the fixings. I was hoping I could just remove the tie rod end and slip it on?
Thanks
Screech16v
MK3 20vt AGU
Re: OS Steering Gaitor possible in situ?
31 August 2011, 17:59 »
Yeah, did one a few months ago,didnt even remove the track rod end,use real sturdy zip ties to secure.
bmouthboyo
Here all the time
31 August 2011, 20:12 »
How did you get it over the joint without removing the trackrod end?
isnt the rubber too narrow?
Screech16v
MK3 20vt AGU
31 August 2011, 20:18 »
Bit of grease,them things strech like fook.
bmouthboyo
Here all the time
31 August 2011, 20:26 »
Nice one, that will help keep tracking reasonable then.
Wayne
Sir Postalot
31 August 2011, 20:57 »
Easier to remove the track rod end.
javalin
Reply #6 on:
01 September 2011, 08:31 »
yeah + 1
Then zip ties!
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Youngben8
Reply #7 on:
03 September 2011, 20:55 »
Just count the turns you make when removing the rod end then re-fit with the same amount of turns and lock off. Simples
Golf mk3
hardmonkeys
