Golf mk3
hardmonkeys
ABF Throttle position sensor
Topic: ABF Throttle position sensor (Read 2426 times)
Chris_cj
Just got here
30 August 2011, 10:53 »
does anyone know if i would be about to use a TPS off say an 8v gti or would it have to be off the 16v?
its the 2 pin one at the back of the throttle
cheers guys
tshirt2k
Been there...Done that...
Re: ABF Throttle position sensor
30 August 2011, 11:06 »
The 2 pin isnt the TPS. Thats the throttle closed switch. TPS is 3 pin
Mk3 ABF 16V
T
Megasquirt V3
Chris_cj
Just got here
30 August 2011, 11:20 »
cheers for the reply dude,
the garage said it was the tps on the back so if the tps is on the front i really dont know which one to get.
from experiance wich would you say would be the most likely to need changing?
cheers
dennis10
GTI forum regular
30 August 2011, 15:17 »
What are the symptoms your supposed faulty TPS is showing?
I'd be suprised if it was the TPS causing any jip. I'd put any running/idling problems down to the ISV (idle stabilization valve)
tshirt2k
30 August 2011, 21:08 »
Garages sometimes don't know what they're on about. As above, what are the symptoms.
Mk3 ABF 16V
T
Megasquirt V3
Golf mk3
hardmonkeys
