Author Topic: Fault codes on my mrs corsa  (Read 1490 times)
Offline Toby
  • Car - less
« on: 29 August 2011, 22:38 »
had a light come on the dash, scanned it
threw up -
P0141 OBD-II  O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
and found this website http://www.obd-codes.com/p0141
any idea what needs to be replaced? and why its come up on a 57 reg corsa D?
Currently down under
Offline Ant1981
  • Feed me, prod me
Re: Fault codes on my mrs corsa
« Reply #1 on: 29 August 2011, 22:44 »
Lambda sensor?
'09 Kawasaki Ninja ZX-6R
Offline Toby
  • Car - less
« Reply #2 on: 29 August 2011, 22:46 »
thats what i was thinking, but its the word "oxygen" thats throwing me  :undecided:
Offline Ant1981
  • Feed me, prod me
« Reply #3 on: 29 August 2011, 22:50 »
Yeah that's another name for one mate, 02 (oxygen) sensor.
Offline Toby
  • Car - less
« Reply #4 on: 29 August 2011, 22:50 »
thanks ant
further searching - lambda sensor , hope tis not to costly!
Offline Toby
  • Car - less
« Reply #5 on: 29 August 2011, 22:53 »
will a lambda sensor from engine fit, or must it be a 1L .. or can it be from corsa b/c/d?
Offline Ant1981
  • Feed me, prod me
« Reply #6 on: 29 August 2011, 22:56 »
Could be around £120 or so, VW ones are about that. Essentially, could be the same sensor, but best to check you do put the right one in just incase.
Offline Toby
  • Car - less
« Reply #7 on: 29 August 2011, 23:00 »
she wont have much wages left on friday then :laugh: iv got 3 grand next to me itching to buy a new car spose i could lend  :rolleyes:
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 29 August 2011, 23:07 »
Three grand? Ooooooh, have a lash up holiday!
Offline cняis
« Reply #9 on: 30 August 2011, 00:21 »
Different vehicles generally have different lambda sensors as the number of wires/length of wires and connector plug can vary. The actual sensor part is usually the same.
"Universal" lambda sensors can be bought cheaply from any motor factors, around £40-£50. Universal ones are sold with bare ends and have either 1,2,3 or 4 wires.
All you need to know is how many wires yours has. Then chop the plug off the original, and connect it to the replacement sensor.
Cheap lambda sensors dont tend to last very long though. If you're opting for aftermarket and keeping the vehicle, go for NTK (part of the NGK group), Bosch or any other well-known make.
