The garage
Throttle body- easy change?
Topic: Throttle body- easy change? (Read 1788 times)
Mart8V
I really should know better by now.....
18 April 2005, 19:23 »
Have been asked by a mate at work to look into a throttle body swap on her Mk3 1.4 CL. I have seen it described as a "bolt off, bolt on" job. Is this correct?!
Part is about £157 from GSF, or less from breakers, but she is being quoted some outrageous amount of labour by garage.
Any tips much appreciated!
AudiA8Quattro
Forum addict
Re: Throttle body- easy change?
18 April 2005, 20:01 »
Check my website, link on the bottom.
There is a how to guide for removing the throttle body and cleaning it, the guide is for1.8 16v mk2, but most models are similar.
What is the problem with it? why does it need replacing?
Mart8V
18 April 2005, 20:18 »
Thanks for that. Apparently the revs keep dying and it is cutting out at idle. Has been on a VAG diagnostic apparently and that was the recommendation from them, but matey is a little strapped so thought of paying main dealer prices is a little too much....
Gambit
Forum addict
19 April 2005, 09:20 »
it wont be the throttle body. my mate has the same prob with his wee 1.4 seat. it's the MAF sensor on them that goes. wont show on diagnostics either!
richandhazel
Global Moderator
Forum addict
19 April 2005, 13:00 »
MAF sensor is a common problem. They do seem to deteriorate over time/use and the only solution appears to be replacement. My Dad's Audi A6 TDI was suffering with appaulling acceleration, especially in 2nd gear and generally underperforming. I tried cleaning the MAF, which didn't help. £70 later and new MAF it totally transformed the car. Goes like a rocket now
He did take it to Martins at Basingstoke and the Audi technician plugged his lappy in and they went out for a drive. The technician told Dad to accelerate in certain gears and at certain times and he was able to confidently diagnose that it was the MAF. As Gambit says, it won't come up in a diagnostic check but if they do that they can prove it 100%.
Mart8V
19 April 2005, 17:45 »
Thanks for that, guys. Will keep an eye on the MAF as well. Apparently the problem has mysteriously cleared up since the diagnostic at the main dealer....
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
20 April 2005, 12:52 »
Theres a sticky post on here somewhere that describes how to strip them down and clean the electrical contacts...
The garage
