Author Topic: Mountain bike maintenance.  (Read 974 times)
Offline Dan n Nic
« on: 28 August 2011, 19:33 »
Does anyone know how you unstick a disc brake piston? (& yes Hydraulic!)
Cheers!
« Last Edit: 28 August 2011, 19:37 by Dan n Nic »
Offline Ant1981
  • Feed me, prod me
Re: Mountain bike maintenance.
« Reply #1 on: 28 August 2011, 20:25 »
It's possibly seized. Maybe see if there's a piston overhaul kit for it.
'09 Kawasaki Ninja ZX-6R
Offline Dan n Nic
« Reply #2 on: 28 August 2011, 20:32 »
If that is the case I think I'll just be dropping it off to the bike shop!   :grin:
Offline rob.043
« Reply #3 on: 29 August 2011, 08:20 »
you can have a go at pumping out the pistons one at a time, with the disc and pads removed, clean up around the piston as much as you can and lube the seal with the relevant hydraulic fluid as you pump out and return the piston a few times. wipe away excess fluid before reassembly. removing pistons entirely would be good if you can reblead...
Offline Ridg
  • TDI - Soot Happens!
« Reply #4 on: 29 August 2011, 09:53 »
+1
take the caliper off the frame / fork
remove the pad
bit of oil / brake fluid (depends on your brakes) on a cotton bud
run this round the lip of the piston
try gently to push the piston back in using a closed spanner say 6mm
if you don't get any joy then you're looking at either needing to change the piston / seal or the whole unit depending on the brake.
the hardest part here is getting the piston out and then re-bleeding, it does give you the opportunity to fit pimp braided cables though  :wink:
Offline Dan n Nic
« Reply #5 on: 29 August 2011, 20:24 »
Thanx guys, but it doesn't seem to want to budge so gonna take it into the bike shop!
