Author Topic: DanChave's MK3 Volf - Sold ;)  (Read 150185 times)
Offline search
Re: DanChave's MK3 Volf - Wheels are painted :)!!!
« Reply #410 on: 04 March 2012, 11:00 »
I'n the end id like to have my car in another colour but its just so expensive. your lucky you know what your doing. i'v gone through 4 rattle cans and all the halfrauds around me have now ran out. so mighty pay the extra for them to make a can up for me.
Don't ever get paint from Hellfords...cause when your half way through a job and you have to wait for a delivery the next batch are always a shade different...eg Painting 3 wheels Ford Diamond white...the 4th came out cream!  :angry:
Just got to a spray shop or if you can afford to do that use matt black  :grin:
LOL so true man so true.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline DanChave
« Reply #411 on: 10 March 2012, 16:52 »
After putting up with my age old JVC head unit jumping on every bump on the road, randomly refusing to play CD's and generally being quite pants, I have decided to jump into the 21st century and get a new stereo :)
In the end, I went for a Sony CD/MP3 head unit with 4x52 Watt output, aux out, 3.5mm jack and USB port. Not bad for a little over £60 from Amazon :)
Offline DanChave
« Reply #412 on: 16 March 2012, 14:37 »
Well, today was productive :) Went up to Exeter to give a quote for some paintwork and booked the guy in to get it done! The I went and had a chat with the guys in GFS who pointed me in the direction of the cold start temperature sensor for being the route of my starting issue. I picked up one of those and a new O ring for just over a tenner and headed home :)
Got back and my new stereo had arrived as well! Bonus! So I set to, and half an hour later, sensor in and problem seems to be solved! The real test will be weather it starts alright tomorrow morning!
I fitted the stereo as well, got it all set up, and thanks to Sony's wiring harness, swapped a couple of wires round, and now the memory function (which I could never get to work on my old JVC unit) works a treat!
Happy days all round really :)
Offline Seanl
« Reply #413 on: 16 March 2012, 20:59 »
Glad everythings going right for someone!  :grin:
Offline stow1985
  • 'when im cleaning winders'
« Reply #414 on: 16 March 2012, 22:49 »
^^^ :grin: :grin:
Hope the Temperature sensor does the trick for you, It didn't with me!  :sad:
Offline DanChave
« Reply #415 on: 17 March 2012, 09:58 »
Yeah man, I have been reading about your troubles! You'll get it all sorted soon :)
^^^ :grin: :grin:
I jumped in the car this morning to see if the temperature sensor had fixed the problem, I was actually really nervous turning the key lol! She started first time though, and no loss of power :) Problem solved!
Now I have to replace the same thing on my dads MK3 lol!
As a treat for the old gal, now that she's better, I decided I would fit some washers behind the rear stub axles to get a bit of negative camber so I can squeeze my 30mm adapters off the front onto the back, swap my 25mm adapters for some 35mm ones of a mate to push the fronts out a bit more, and play with the coilovers to get her sitting a bit better!
Literally just stepped out the door and its now pissing it down.
Hopefully it will be dry tomorrow and I'll get it sorted then :)
In more body related news, I have tracked down four straight doors to replace mine! once I have these, I will have everything I need to complete the bodywork for this year!
Offline stow1985
« Reply #416 on: 17 March 2012, 10:29 »
Some people get all the luck  :grin:
Offline DanChave
« Reply #417 on: 17 March 2012, 10:36 »
Certainly not Seanl It would seem! At I don't know how lucky buying a new dizzy, rotor arm and throttle body to inlet gasket before buying a temp sensor for a £10 to finally fix the problem is lol!
Although I am SOOO glad its fixed now :)
Offline DanChave
« Reply #418 on: 17 March 2012, 17:33 »
Had to do something today so I nipped out between it pissing it down and sanded down and painted up a spare grill badge I had nocking around :)
Before
After
And a couple of shots of my new Sony head unit :)
Although I have replaced the heater dials with some OEM black ones now!
More tomorrow if the weather is alright!
Offline stow1985
« Reply #419 on: 18 March 2012, 21:56 »
That's on my list too!  :grin:
