Author Topic: ESP and tyre pressure warning lights staying on.  (Read 2511 times)
Offline max357
« on: 28 August 2011, 09:01 »
Hi, has anyone had this problem? Both esp and tyre pressure warning lights are on and stay on. Pressing the reset/onoff buttons doesn't do anything. Its a December 06 Gti with 29k. cheers
Offline bacillus
Re: ESP and tyre pressure warning lights staying on.
« Reply #1 on: 28 August 2011, 09:52 »
Sounds like there may be a problem with an abs sensor or worse case scenario a problem with your abs pump.
Get your car scanned to see what fault code is stored.
Without traction power is nothing!
Offline max357
« Reply #2 on: 31 August 2011, 08:55 »
Hi,
just been told by VW that its showing error code G202 which they tell me is a 'rotation rate sensor'. quoting me £700 to have it replaced. Anyone had this problem. they say the good news is that its not the ABS pump (yet).
Offline AlanD
  • MK5 2.0T 16v
« Reply #3 on: 31 August 2011, 09:42 »
Ouch. Where in country are you based? VW will always charge you much more than a good local VAG specialist. There is no NEED to take it to VW.
