Author Topic: arb drop links  (Read 2313 times)
Offline Dan_GTi8v
arb drop links
« on: 28 August 2011, 00:13 »
How do you remove the drop links from the anti roll bar, do they just bolt on? I can see what looks like a bolt from the drop link o the arb, but I cant tell if it is part of the link or the arb as its so rusted it looks like its all 1 piece?
cheers
Offline nikkiy9
Re: arb drop links
« Reply #1 on: 28 August 2011, 08:21 »
they just slide on, with a bolt into the bottom arm, 10 min job, just lube the arb and droplink so the arb goes thru fully
VW BUSH
Re: arb drop links
« Reply #2 on: 28 August 2011, 14:25 »
Change them for Cast ones, not the welded cheap jobbies from ECP/GSF I had both go in a matter of weeks a few years back and poped the drive shaft cover each time :angry:.
Dead easy job, even easier if you have both wheels off and up in the air :smiley:
Offline Dan_GTi8v
Re: arb drop links
« Reply #3 on: 28 August 2011, 20:13 »
I cant even get the old ones off, theres deffinatly no 'sliding' going on lol ive had a ring spanner on it and given it some welly with a hammer but there not budging
Offline tweed
Re: arb drop links
« Reply #4 on: 28 August 2011, 20:19 »
I have read that there are two types. one that push and one that bolts. But I cant remember that well  :laugh:
edit: that might be mk4 lol I think mk3 are push.
Have you used wd40?
« Last Edit: 28 August 2011, 20:23 by tweed »
Offline Dan_GTi8v
Re: arb drop links
« Reply #5 on: 28 August 2011, 23:46 »
yep tried everything. I'm assuming the old ones are the same as the new ones, one end is a hole that fits to the wishbone with a bolt through it, the other end (which I cant get off) is threded with a bolt on the end. My only guess is they have rusted so badly the metal has stuck together
Offline geeksteve
Re: arb drop links
« Reply #6 on: 28 August 2011, 23:58 »
Mine were threaded. Spanner on it, hit LOTS with lump hammer. Lots of pen oil on it. More hammering. Then attacked it for about 10 mins with a spanner and it finally let go. Almost broke my finger when it did go.
Keep with it. Get angry at it.
S
Offline nikkiy9
Re: arb drop links
« Reply #7 on: 29 August 2011, 11:41 »
Or hammer a screw driver between the rubber and arb to release the rust
