Golf mk2
Timing gun how!
Topic: Timing gun how! (Read 1439 times)
emery1990
Timing gun how!
26 August 2011, 19:07 »
Just got hold of a timing gun, but I don't know where to point it, it is a snap on one with an advanced dial on it. What advance do I set it to, Ive got a 9A with a kr head. 10btdc rings a bell.
reading that post below
I have to point it at the flywheel hole. As said what setting do I put it on and to what btdc should I set it at.
Thanks
Last Edit: 26 August 2011, 19:09 by emery1990
The Mighty Elvi
I'm better than you today.
Re: Timing gun how!
26 August 2011, 21:13 »
http://www.golfgtiforum.co.uk/index.php?topic=56707.0
emery1990
Re: Timing gun how!
26 August 2011, 23:55 »
Erm, does help thanks, but pretty sure I was told my idle timing should be around 10btdc. I done what was shown above, could hardly see the mark was shaking loads!
Mew
Re: Timing gun how!
27 August 2011, 12:21 »
Set the gun to zero advance and follow the instructions in the link above.
If you want 10 degrees advance then set your gun to 10 degrees and use the tdc mark on the flywheel, rather than the 6 degrees btdc marker.
emery1990
Re: Timing gun how!
27 August 2011, 13:20 »
Ok thanks mate.
Golf mk2
Timing gun how!
