Author Topic: 96 8V gti with broken Lambda wire on loom side  (Read 1418 times)
Offline twotwofour
« on: 26 August 2011, 18:46 »
The brown wire has come away from the plug, its been like that a while as its a bit green and corroded.
Which function am i loosing from the brown wire? I suspect heating element as fuel economy is cack until im up to temperature. Then i'm getting around 27-30 mpg.
Is it easy to unplug that bit of the loom?
Looks like a big job.
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline javalin
Re: 96 8V gti with broken Lambda wire on loom side
« Reply #1 on: 30 August 2011, 14:57 »
visit VW for some repair wire.  If you can solder.
Suggest you get the high temp version for where that connector sits.
http://javalins.wordpress.com/vw-golf-mk3/vw-electrical-connectors/
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline nikkiy9
« Reply #2 on: 30 August 2011, 15:10 »
i have a lambda sensor sitting here if you want it? £15 and it's posted
Offline twotwofour
« Reply #3 on: 01 September 2011, 18:50 »
It's on the wiring loom rather than the lambda sensor with plug. It's bust right by the plug so there isn't anything to solder to really. Just need a piece of the engine loom and I'll solder in the new plug
Offline birch
« Reply #4 on: 01 September 2011, 19:13 »
vw did me the plug on the loom side with 4 lenghts of new wire on each terminal, just cut old plug off and soldered wires together, cost about £5 from vw main dealer.
Offline javalin
« Reply #5 on: 02 September 2011, 08:16 »
top banana!  Good one.
Offline twotwofour
« Reply #6 on: 02 September 2011, 12:41 »
Awesome cheers!
Offline lankylari
« Reply #7 on: 05 September 2011, 21:48 »
fair play thats cheap for vw.
