Author Topic: who knows what this means? pics inside. update  (Read 3810 times)
Re: who knows what this means? pics inside. update
« Reply #10 on: 26 August 2011, 20:44 »
You can get the new / replacement clocks set to the same mileage.
Offline Seanl
« Reply #11 on: 26 August 2011, 20:59 »
Yeah both the square and rectangular ones are EPROMs (electronic programmable memory). The can loose functionality after time and dump memory due to. Corruptions through voltage/signal/current etc. Only thing is you will need to find out which one controls what etc; as you could well dump your milage by removing them. Better to get a new set and get your current milage duplicated by a qualified technician mate
Offline tweed
« Reply #12 on: 26 August 2011, 22:02 »
Oh cool thanks Wayne and Sean! I didn't know you could do that  :embarassed: Are volkswagen the only people that do this?
Offline Seanl
« Reply #13 on: 27 August 2011, 07:29 »
Speak to Brad Kells, he knows someone local to him that does it, but you maybe able to get it done local to you. Not sure what they would call themselves tbh, and not sure if the dealer does it. Apparently it's not illegal if its done properly and I suppose they have to register it.
Gavv8
« Reply #14 on: 27 August 2011, 08:37 »
Of all the things to break on a 30000 mile car, very annoying :angry:
Offline forsh
« Reply #15 on: 27 August 2011, 16:43 »
update. it's the clocks  :cry: just put the 8v gti clocks in the vr6 and it did the same.
Is the big chip in the middle the memory?
vr6 is 6 cylinder car gti is 4
clocks will be wrong in rv6 from a gti
cerr means milage error in the ecu and the clocks
get it on vagcom and reset the clocks to the ecu milage
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #16 on: 27 August 2011, 16:52 »
Hey mate i had my miles corrected when i got my 16v annie clocks as i wanted them to read what the engine does
i can get them done for £35 ish local to me (leeds) took the guy around 5 mins to do
Carbon chip tuning can also do it, they are a forum sponsor, they charge around £50 to do the job
hope this helps
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tweed
« Reply #17 on: 27 August 2011, 19:42 »
vr6 clocks didnt show it and the rev needle didnt go all the way round when i plugged them in 8v gti  :undecided: it has fall vw history and the millage goes up. How do you know cerr means mileage error?
Offline tweed
« Reply #18 on: 27 August 2011, 19:44 »
hope this helps
yeah great help thanks. Leeds is a bit far for me but I will check out cct. Nice one
Offline forsh
« Reply #19 on: 30 August 2011, 17:22 »
Quote
vr6 clocks are programed to work on vr6 cars
6 cylinders and that
your rpm will be wrong
think there is a setting on vagcom that can make the clocks reset to the ecu milage
« Last Edit: 30 August 2011, 17:25 by forsh »
