Author Topic: KO3s turbo pressure  (Read 3002 times)
Offline mac_GTI
KO3s turbo pressure
« on: 26 August 2011, 10:54 »
i have a re-mapped golf gti turbo with the KO3s turbo, recently put a manual boost control on to by-pass a boost problem. ive been looking up the best, safe boost pressure to run at but have ended up confused with people saying 0.6 bar and others up to 1.6bar. I currently have it set at 1 Bar exactly. any help welcome
Offline rs_dude
Re: KO3s turbo pressure
« Reply #1 on: 26 August 2011, 11:22 »
What map and what is the spec?
Offline StusDUB
« Reply #2 on: 26 August 2011, 12:44 »
IMO I would never run a MBC on a golf 1.8T as you will melt pistons etc but the boost pressure is as follows,
0.6 bar is stock
1 to 1.2 bar mapped
Offline mac_GTI
« Reply #3 on: 26 August 2011, 21:31 »
its mapped for a KO3s turbo, de-cat sports exhaust, sports filter, dump valve etc
« Reply #4 on: 26 August 2011, 23:51 »
Manual boost control is a silly idea, why not sort the problem before you break something.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 27 August 2011, 09:48 »
You wont melt a pistion on a 1.8T engine the ecu will fuel for the air drawn via the maf. (only if the fuel pump or lambda sensors are faulty will you melt a piston)  depending on engine code you will get throttle or N249 cut  as you try to rasie the power.
To turbo your boost up you really need to log the AITs and timing.
Nick
 01455 617233
Offline golf-sib
  • Турботазик
« Reply #6 on: 29 August 2011, 00:35 »
Weren't the AGU engines the only ones with no fail safe as I remember the AUM's will override the throttle to cut things?
Also what is the best way to wire the MBC in, to bypass the n75, run it in series or parallel?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
