Poll
has any one fitted these jom day time running lights to a mk4 golf
drl lights mk4
0 (0%)
wiring issues on drl
0 (0%)
Total Members Voted: 0
Author Topic: fitting and wiring of jom day time running lights on a mk4 golf 2003  (Read 2414 times)
Offline partyarty24r
hi everyone new here to this site i have a mk4 golf 2003 and recently purchased at set of jom day time running lights of venom motor sport uk.which fit on lower part of bumper were grills are i had a few issues with these lights in the wiring of them and as the wiring diagram is in german and not very clear on how they should be wired. anyway this kit comes with two small black boxes and have one red wire and one black wire and also one white wire. the way i wired them is took a positive feed from ingition to the red wire and black attached to earth on battery terminal and white wire to side light feed so when you turn on side lights the drl lights extinguish out now they worked for a while and then started flickering and then the right hand drl light now have only three showing and the other ones comp out and the left side showing signs of flickering when left on for a short period of time. have i done anything wrong or does anyone else had this problem or can help to slove this matter. i have informed vemon motorsport of this problem but no satisfaction to date. look foward to any replies on this topic folks. cheers arty. :undecided:
« Last Edit: 24 August 2011, 21:19 by partyarty24r »
