Author Topic: 1.8T AUM misfire when cold  (Read 2996 times)
Offline rs_dude
« on: 24 August 2011, 12:49 »
I have a MK4 Golf 1.8T (AUM) which seems to misfire on light throttle when cold.
It has had 4 new coilpacks from VW under re-call. Maf was recently replaced, again OEM.
The car is 'Stage 2' mapped by AMD.
It does not bring up any management lights or codes, any ideas?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: 1.8T AUM misfire when cold
« Reply #1 on: 24 August 2011, 19:35 »
Air leak or issues with SAI?
 01455 617233
Offline rs_dude
« Reply #2 on: 25 August 2011, 11:47 »
The SAI isn't connected to the airbox as i have an aftermarket enclosed filter, could this be the problem?
I did check the catch tank and FMIC/boost hoses for leaks, all seems fine.
Thanks for the reply!
Offline richw911
« Reply #3 on: 29 August 2011, 21:58 »
Secondary air pump fault?
« Reply #4 on: 29 August 2011, 23:08 »
Yes it could well be the problem :smiley:
Offline rs_dude
« Reply #5 on: 30 August 2011, 15:00 »
Thank you for the replies.
I'll have to find a way to connect it to my air filter!
