Author Topic: 16v kr cylinder head questions  (Read 1915 times)
Offline chrissy_88
« on: 23 August 2011, 23:02 »
hey folks finally got round to removing the head from the car probaly the easiest head iv ever removed,expecting too see a melted piston or valve but just a huge hole in the head gasket between 2 and 3  :smiley
needing a bit help and knowledge however
can any1 tell me the part number or where i can get the injector sleeves tht sit in the inlet manifold,kinda struggling too find any1 tht does them ?
i had to brake an injector to get the inlet manifold off,are there diffrent injector types for this engine ?
every time iv done a head iv always got it skimmed,how much can i skim it ? iv checked it with a straight edge and its ok to be fair so not sure wether its worth my while just leaving it
any help much appreciated cheers
Re: 16v kr cylinder head questions
« Reply #1 on: 23 August 2011, 23:40 »
VW will sell the injector seats, You will need to use an injector from the same engine as 16v is different.
Also yes get the head tested and checked.
Offline danny_p
« Reply #2 on: 24 August 2011, 00:28 »
minumum thickness for head is listen in the haynes.  tbh you just sim them enough to get any distortion out and clean the face up.
16v heads tend to need a skim, you'll find that the diveders between the chambers tend to move a littel esp if the gasket has blown there.  i usally knock 5 tho off and just look and if there are patches of metal that arn't clean another 5 tho comes off
all the VW's have gone bar 1.
Offline chrissy_88
« Reply #3 on: 24 August 2011, 21:50 »
cheers guys,al just get it skimmed and tested,and get on the blower to vw to get thte injector seats and an injector
