Author Topic: Whooshing Noise  (Read 1805 times)
Offline DubaiGTI
Whooshing Noise
« on: 22 August 2011, 13:01 »
Afternoon gents/ladies,
I've just returned from a 4 week break.  I've noticed when I start my car and blip the throttle in park mode I hear a whooshing noise.  The car is performing normally, no issues from a driving prospective.  Just an odd noise.
Any ideas?
Jimmymature
Re: Whooshing Noise
« Reply #1 on: 22 August 2011, 15:16 »
Any ideas?
I'm a complete noob but sounds like a leaking DV valve, I'm sure the experts will be along soon to correct me!
Jim
Offline KennyGTI
Re: Whooshing Noise
« Reply #2 on: 22 August 2011, 15:58 »
Have you changed your induction? It's just the air being re-circ'd from your turbo to induction. Perfectly normal. If there was a leak the ECU will pick up on it.
APR Stage 2+
Offline DubaiGTI
Re: Whooshing Noise
« Reply #3 on: 24 August 2011, 08:56 »
I had the Revo stage one upgrade done awhile back.  Car is driving lovely, so as you say probably no cause for concern.
Thanks for the responses.
Offline Agreeable Slick
  • Unit
Re: Whooshing Noise
« Reply #4 on: 24 August 2011, 09:03 »
Worst case it will be a split pipe. BUT 1) the ecu would detect it and 2) seeing as you are doing it at idle I doubt it.
It could be the remap diverting a little more air back into recirc due to a slight overfuel at initial start up.
