Author Topic: How much should i ask?  (Read 1028 times)
Offline GreDA
« on: 17 April 2005, 16:54 »
I'm tryin to sell my mk2 gti 3dr 16v. Its atlast grey (bit chipped) and its got bk racing wheels and corbeau seats. The gera linkage is a bit dodgy so sometimes when gpin for 1st u get reverse! Otherwise the interior is neat and the mechanicals are perfext. I was lookin for about £900. Will i get that?
The list of problems gets longer and longer! Suspension, gear linkage, clutch, random revving at idle, brake hoses, rusty boot, dodgy wheels, and nasty paint on bonnet. I love a challenge!!
Re: How much should i ask?
« Reply #1 on: 17 April 2005, 17:05 »
Price sounds about right although the seats might put some people off, do you have the originals?
As for the linkage problem, sounds like you need a gearlever ball repair kit from VW. Its pretty straightforward to do but a bit fiddly. Part number is 191 798 116A, I would recommend you get the genuine kit the pattern kits are pretty crap!
1. Remove the gearstick gaitor & centre console to give you more room to work
2. Undo the 2 10mm nuts either side of the gearstick.
Now get under the car
3. Remove the exhaust centre heat shield by removing the 6 nuts/clips holding it on, then rotate it round the exhaust an off the car
4. Shove the housing up into the car, it is only held in by gravity & grease at this point
5. Remove 4 13mm nuts holding the plate
6. Now get back in the car, pull up on the stick and push down on the plate you have just undone
7. Next Jiggle the housing about untill you can get it out
8. If the ball looks like it is worn you can remove it, I didn't bother as it looked OK. Its tricky, you need to press the ball upwards while someone holds the gearlever down, then you need to remove the split pin. Not an easy task!
9. Refitting is the reverse of removal
