Golf mk3
hardmonkeys
ABS Sensor (rear)
Topic: ABS Sensor (rear) (Read 683 times)
Richie_C
ABS Sensor (rear)
21 August 2011, 16:52 »
Are the abs sensors for the rear same as those on the front as in unplug the old ones remove and replace or are the rears the ones with the long lead that goes up under the seats or is that just 5 doors?
VW BUSH
Guest
Re: ABS Sensor (rear)
21 August 2011, 18:26 »
Fronts and rears are different, early/late rears have a different length cable
javalin
22 August 2011, 10:55 »
on 5 doors, certainly. Dunno on 3 door.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Golf mk3
hardmonkeys
ABS Sensor (rear)
