Author Topic: Anyone done this sticky handbrake fix??  (Read 1190 times)
Offline luckycharms
« on: 21 August 2011, 15:23 »
My handbrake occasionally sticks, the internal return springs are too weak...
easy fix, put the car over the pit and free it up with a vice-grips, but a pain in the a$$ to have to keep doing it every month!
Basically I'm wondering if the mk4 and mk3 handbrake brackets are similar, and if this mod will fit directly on...??
Or do I have to get different springs?
http://www.clubgti.com/forum/showthread.php?t=207880
Offline tweed
Re: Anyone done this sticky handbrake fix??
« Reply #1 on: 21 August 2011, 15:38 »
Are you on about freeing up your caliper?
Offline luckycharms
« Reply #2 on: 21 August 2011, 15:51 »
Yes.
When I release the handbrake, the cable slackens from the stop, but the arm doesn't rotate to its 'off' position. Its only the handbrake, foot brake releases perfectly.
If I clamp a vice grips over the arm and monkey it up and down a bit it frees up for a few weeks
Offline luckycharms
« Reply #3 on: 21 August 2011, 19:55 »
And what I want to know is are mk3 and mk4 rear brake calipers similar?
I want to do the same fix on my mk3, just wondering if i can order the same part numbers that guy used on mine?
