Author Topic: handbrake light & ABS light  (Read 3630 times)
Offline Richie_C
« on: 19 August 2011, 22:48 »
Finally got all my discs and pads changed and fitted with new ones and new o/s/r caliper.
Got 3 problems though.
1: Bleed nipples welded shut and sh!t scared of snapping them or rounding them off
2: ABS light is now staying on when car is fired up
3: Handbrake light goes off after firing up but then after about 30 seconds comes back on
The handbrake is working fine (well it will be once i can get the brakes bled)
Any help and ideas on all 3 problems?
Re: handbrake light & ABS light
« Reply #1 on: 19 August 2011, 23:20 »
Handbrake light is also fluid level so might be worth checking the fluid.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 19 August 2011, 23:29 »
Soak your nipple in penertrating fluid,hmmm that sounds bad  :laugh: get the best fitting socket on it and be brave its got to undo,as for your other issues .....
http://www.clubgti.co.uk/forum/showthread.php?t=224427
Offline Richie_C
« Reply #3 on: 20 August 2011, 09:33 »
At work all weekend got the car at work so when i can iam popping down and giving each bleed nipple a soak in wd40.
Fluid level is fine i havent checked the handbrake switch yet
Have read on a few post on here that if more than 1 abs sensor is out this can cause the handbrake light to come on!!
Offline kr1s77
« Reply #4 on: 20 August 2011, 10:05 »
i have this, i fliud level is fine, i bought a new handbrake switch and changed the osf spped sensor and still on  :sad:. im gonna take a look at the abs ecu controller when i get the chance. when read it shows the abs pumps is faulty. at the moment i have unplugged the the connector in the dash for the airbag and abs as the handbrake light goes off when this is done (the handbrake light on constantly was really bugging me lol). if i take the abs controller off the abs pump can i drive the car without it??? i mean will i have any brakes??
ASV 1.9 TDI 110
Offline jonno74
« Reply #5 on: 20 August 2011, 12:22 »
I had a similar problem on my Mk3, the ABS light was stuck on, and it was throwing up a 'ABS hydraulic pump fault' on the OBD scan , however after some digging with the diagram and meter, it turned out to be the light module that was causing the fault. There was a comparator chip which had failed in mine. As soon as I disconnected it and re-scanned - no fault present. Replaced the module, all is ok.
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 20 August 2011, 13:02 »
Yes you can drive without it and still have brakes,i did this last week for several days no issues.
Offline gasketface
« Reply #7 on: 20 August 2011, 13:30 »
I just sorted exact same faults on mine.Bought a cheap code reader off ebay (£20 odd) and it showed 2 faults :- both front abs sensors.
Would not clear codes until sensors had been replaced.Replaced one at a time and first fault reset turned off handbrake light and second turned off abs light.Sorted !.
Offline nikkiy9
« Reply #8 on: 20 August 2011, 15:00 »
i had the bleed nipple issue, i snapped the complete bolt on the nipple, tried a torx bit into the nipple and snapped that in there, last choice was to get a new set of calipers and then drill out the damaged nipple
Offline Bellend
« Reply #9 on: 20 August 2011, 15:35 »
My GTI handbrake light would come on and stay on if you absolutely anchored it and the wheels locked up (was an ABS fault but bulb had blown) and would go out if you turned the igntion off and on again.
So I'm fairly positive the handbrake light has something to do with the ABS.
Where all my moneys went.
