Author Topic: Footwell Lighting Issue  (Read 4244 times)
Offline mrDMH
« on: 19 August 2011, 22:23 »
Hello,
Gone to replace my footwell lights for red LED's today, fitted one works fine..
fitted the second and it wont come on, and it also cuts out the first one after 5 seconds. If i put one normal and one LED in they work fine..
Is this a voltage issue, wrong bulbs?
I did check the other bulb and it works fine!
Offline Jimp
Re: Footwell Lighting Issue
« Reply #1 on: 19 August 2011, 22:54 »
Try swapping it around so it faces the other way? With LED bulbs they need to be installed the right way around to work, it's really easy to mix up.
Not low enough mk5
Not on the road enough mk3
Offline weston
« Reply #2 on: 21 August 2011, 09:46 »
That'll almost certainly be the issue
Offline mrDMH
« Reply #3 on: 21 August 2011, 10:21 »
Looks like you were right!
However, has anyone noticed that since changing to LED in the footwell, the lights only stay on for about 5 seconds rather than until lights are switched off or engine ingited?
Offline weston
« Reply #4 on: 21 August 2011, 20:20 »
Not noticed this myself, bit odd
Offline mrDMH
« Reply #5 on: 22 August 2011, 21:59 »
Very weird, they are both working but don't stay on very long!!! Only long enough for a glance then they go off, other lights stay on fine.. Hmm :(
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
« Reply #6 on: 23 August 2011, 06:30 »
Did this on mine too - only on the footwell lights too, not the overhead ones. Never got to the bottom of it but suspect they weren't compatible with the canbus or something.
Offline mrDMH
« Reply #7 on: 23 August 2011, 08:15 »
Aha! Sounds like you might be right, is there such a thing as canbus friendly LEDs?
Offline Rhyso
« Reply #8 on: 23 August 2011, 09:27 »
Yes there is  :tongue:
Offline mrDMH
« Reply #9 on: 23 August 2011, 12:45 »
Link me breadbin!
