Author Topic: Front suspension wobbly feedback....  (Read 1762 times)
Offline javalin
« on: 19 August 2011, 09:52 »
Chaps,
Fitted poly-bushes on the front suspension a while ago - mk3 golf GTI.  Since then the car is fine on new smooth (i.e. tarmac'd) roads, but feels wobbly as f**k on roads with lumps or tramlines on.  Also worse in the wet bizzarly.
Feels like sometime is shifting when you turn into a corner, you get a weight shift feeling, you correct for it, then its fine.  Just that initial transfer when you change direction.  Feels like the bottom of the wheel (wishbones) is moving maybe, but the ball joints are also new....
Tracking has been done by VW since then and is now correct.
All bolts tight as far as I can tell.
Any ideas?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline AudiA8Quattro
Re: Front suspension wobbly feedback....
« Reply #1 on: 19 August 2011, 10:05 »
Is there any play when you jack it up and rock the wheel?
Offline javalin
« Reply #2 on: 19 August 2011, 10:23 »
not in the wheel.  Slight left-right movement on the steering, but hopefully thats normal.
« Reply #3 on: 19 August 2011, 10:31 »
Any play in the steering column?
Offline javalin
« Reply #4 on: 19 August 2011, 10:33 »
I don't think so - is there a test for this?
« Reply #5 on: 19 August 2011, 21:22 »
Check the steering universal joint for play. Its by the pedals.
Offline javalin
« Reply #6 on: 20 August 2011, 14:25 »
no play in UJ
« Reply #7 on: 20 August 2011, 14:57 »
Next try checking for play in rack and steering balljoints.
Offline javalin
« Reply #8 on: 20 August 2011, 18:02 »
steering ball joints are new and have no play, a little movement in the steering rack, but hopefully thats normal.
