Author Topic: Jetta front  (Read 2576 times)
Offline lemski
  • 16v
Jetta front
« on: 18 August 2011, 20:34 »
Wouldi have to replace front panel or is it a light swap on mk1s. Ide like to see what it looks like but need to know if it will incolve weldong in a new front panel.
Cheers liam
Re: Jetta front
« Reply #1 on: 18 August 2011, 20:37 »
Yes I am sure you need to replace the front panel.
Offline lemski
  • 16v
Re: Jetta front
« Reply #2 on: 18 August 2011, 20:44 »
Not what I wanted to hear waune. What about scirroco frobts. Lights are square. I wanrmt it to look a little differant
Re: Jetta front
« Reply #3 on: 18 August 2011, 23:16 »
Same issue I think  :undecided:
Offline SoundillusioN
Re: Jetta front
« Reply #4 on: 19 August 2011, 09:54 »
This was posted before by Travis and I gave him all the info..  Mk1s have welded in front and slam panels which is the only thing I don't like over the MK2..  You would need to cut out the front end off a donor which are hard to find, also because of how the lights are positioned you would need to relocate the indicators and fit jetta wings...
see this
http://www.golfgtiforum.co.uk/index.php?topic=199343.msg1856091#msg1856091
