Author Topic: Changing power steering rack  (Read 1395 times)
Offline reptiles nd fishin
« on: 18 August 2011, 17:50 »
Hi folks
The pipes on my steering rack are squirting fluid every where so i need to take the rack off and i was wondering if i can do it without dropping the sub frame or does the sub have to come off?
Any advice would be greatly appreciated.
Thanks folks.
Offline madmanmart
Re: Changing power steering rack
« Reply #1 on: 18 August 2011, 17:57 »
The sub frame has to be dropped down to get it out.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
« Reply #2 on: 18 August 2011, 18:22 »
HAPPY DAYS lol
Cheers mate
Offline javalin
« Reply #3 on: 18 August 2011, 18:50 »
interesting, mine are getting a bit rusty.
Do you NEED to take the rack out for this, or could it be done with some wiggling?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #4 on: 18 August 2011, 19:21 »
Its the pipes that run along the front of the rack. I have already changed the feed and return pipes.
Its the ones that have the banjo fitting just in front of the universal joint and one runs half way along the rack (this one is fine) and the other one runs to the other side of the rack (the leaking one). and screws into the top of the rack and there is no way i can get it out without removing the rack. (tried and its solid and starting to round)
I have quick welded it already but that has gave way, and its due its MOT and i need to sort the leak out.
Its driving me daft,lol
its typical that its the most difficult pipe that is leaking (like a fountain) and it would have to be the bottom of the pipe so i cant get in to seal it because of the rack.
Any suggestions?
Offline gasketface
« Reply #5 on: 20 August 2011, 13:36 »
There is no easy way to do that one. :cry:
