Author Topic: Ignition Barrel Removal..  (Read 5521 times)
Offline 85 Mk2 1.8 8v
  • Why Replace, When You Can Refurbish?
« on: 16 August 2011, 18:18 »
Hi All, Does anyone happen to know how to remove ignition barrel from steering shaft on mk3 cabrio? got shear bolt out and stripped down stalks etc.. looks like a splined retainer shaft and a spring. I think the ignition unit is defective as it wont start unless the connection on the back is wobbled. Any help appreciated. Cheerz
Re: Ignition Barrel Removal..
« Reply #1 on: 17 August 2011, 08:54 »
Hi All, This definatley helps!! Check it out
http://forums.vwvortex.com/showthread.php?2532481
Cheerz
