Author Topic: is this a tough job ?  (Read 2491 times)
Offline jigger01
« on: 16 August 2011, 17:53 »
i went today to get my car tracked and was told by the guy that he couldnt do the tracking because ::::
o/s/f   suspension arm ball joint is worn
o/s/f   anti roll bar link bushes worn
n/s/f   lower suspension arm rear bush worn
n/s     steering rack end joint worn
o/s      steering rack end joint slight wear
is this a home fixable job for a novice mechanic
red ones are best( most of the time)
working progres
Offline dansmk3
  • FULL TIME JUNGLIST
Re: is this a tough job ?
« Reply #1 on: 16 August 2011, 17:57 »
o/s/f   suspension arm ball joint is worn - home fix
o/s/f   anti roll bar link bushes worn - home fix
n/s/f   lower suspension arm rear bush worn - home fix - may as well get new wishbones
n/s     steering rack end joint worn - id say these are fixable at home
o/s      steering rack end joint slight wearand these too mate,
do it, get the bits and give it a go
Offline Bellend
« Reply #2 on: 16 August 2011, 18:00 »
Anti roll bar bushes are not a DIY job due to the subframe needing droping down.
Where all my moneys went.
Offline nikkiy9
« Reply #3 on: 16 August 2011, 18:06 »
easy to do if you can get enough height on the car to get under it, a 2 post ramp would be best
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 16 August 2011, 19:57 »
It's only the inner bushes that require it to be lowered though, the drop Link bushes easily swapped without touching the subframe.
« Reply #5 on: 16 August 2011, 20:18 »
Nothing major in fixing those issues.
Offline dan_apps
  • too low for british roads!
« Reply #6 on: 16 August 2011, 20:21 »
anti roll bar bushs...as in the centre ones that simply wrap around the arb, thats piss easy only one bolt each on a mk3 arent they?
Offline nikkiy9
« Reply #7 on: 16 August 2011, 20:38 »
yep, they are a doddle to do
Offline Bellend
« Reply #8 on: 16 August 2011, 20:39 »
Fiddly enough with the subframe in my garage. Gotta be a b!tch just lowering the subframe impossible surely without lowering it least.
Offline javalin
« Reply #9 on: 17 August 2011, 12:05 »
having done most of this this year - my thoughts - http://javalins.wordpress.com/2011/03/11/mk3-golf-notes-on-bushes-changes/
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
