Author Topic: GTI oil?  (Read 2169 times)
Offline KennyGTI
GTI oil?
« on: 15 August 2011, 20:34 »
Got my oil level low light on tonight when I got in my car after work. Restarted the car and it was clear. Anyways, check my oil level and it was a bit low so think I better top it up and see how goes. So can anyone tell me what oil the GTI uses?
Kenny
APR Stage 2+
Offline Steve30
  • Ed30 .
Re: GTI oil?
« Reply #1 on: 15 August 2011, 20:49 »
5-30 longlife oil kenny  :cool:
Tiguan quicker than the Golf
Offline am1w
Re: GTI oil?
« Reply #2 on: 15 August 2011, 21:00 »
Kenny
Read this Kenny.
http://www.golfgtiforum.co.uk/index.php?topic=59317.0
Offline Snoopy
  • Moderator
  • Geoff.
« Last Edit: 15 August 2011, 21:08 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Steve30
  • Ed30 .
Re: GTI oil?
« Reply #4 on: 15 August 2011, 21:14 »
Kenny what did you top up with anyway?  :undecided:
Offline KennyGTI
Re: GTI oil?
« Reply #5 on: 16 August 2011, 07:07 »
Cheers guys, will pick up some 5 - 30w today then.
Never topped it up mate, check it on the dip stick and it was showing very near the low level mark on the gauge. Will top up today :-)
APR Stage 2+
Offline Hyperspace
Re: GTI oil?
« Reply #6 on: 16 August 2011, 10:38 »
Easy - use any oil that states "VW 504.00/507.00 approved" on the back of the bottle.
I.e. any oil from this list - http://www.my-gti.com/2540/ - and pick the cheapest.
Offline Snoopy
  • Moderator
  • Geoff.
Re: GTI oil?
« Reply #7 on: 16 August 2011, 12:10 »
If my oil pressure light had come on mine would be going nowere until i found some oil or fixed the issue.
Mk6 GTI  &  Mk1 GTI
Offline KennyGTI
Re: GTI oil?
« Reply #8 on: 18 August 2011, 07:20 »
Checked my level and although it was on the low line on the dip stick it was still within the parameters hence the reason my light never appeared again. I was confident the was a sufficient amount of oil in the car for it not to run dry, althought, if no oil appeared on the dip stick and the light appeared permantly the car would not be moving an inch.
APR Stage 2+
