Author Topic: oil leak ???  (Read 1809 times)
Offline Dking1983
oil leak ???
« on: 15 August 2011, 20:03 »
hi there im hopeing you ca help me out,ive recently changed the oil in my golf mk2 gti digifant,but there has been a oil leak since i changed the oil,so after some investigating the oil is coming thro the oil sensors and the side of the engine,and one at thr front of the engine.is this due to useing 10w40 semi mineral oil?is it so thin the oil that its getting thro or are both the sensor knackered?
thanks
Re: oil leak ???
« Reply #1 on: 15 August 2011, 20:27 »
Replace the o rings or bonded washers on the sensors
Offline BettyJames
Re: oil leak ???
« Reply #2 on: 18 August 2011, 08:32 »
Is this solution working?
Offline Dking1983
Re: oil leak ???
« Reply #3 on: 18 August 2011, 18:14 »
Hi no this hasnt stopped the leak,im thinkin the oil maybe to thin i dunno
Offline AudiA8Quattro
Re: oil leak ???
« Reply #4 on: 18 August 2011, 18:17 »
Do you mean the oil pressure sensors? these can fail internally and leak oil, try replacing them.
Re: oil leak ???
« Reply #5 on: 18 August 2011, 20:24 »
Thicker oil will not stop it, replace the sensor.
