Author Topic: is this rust?  (Read 6022 times)
Offline _Adam_
is this rust?
« on: 15 August 2011, 13:00 »
im sure it is, but i'm holding onto hope that it's just dirt that needs cleaning out.
if it is rust, how do i take the wing off to treat it?
Offline Rhyso
Re: is this rust?
« Reply #1 on: 15 August 2011, 14:59 »
Get VW to sort it!! 12 year bodywork guarantee no??
Offline Rhyso
Re: is this rust?
« Reply #2 on: 15 August 2011, 14:59 »
Taken from the thread below...
Off the top of my head ive bound to have forgotton something :grin:
Rust checks.
1) Front arches were the liner rubs near the top of the arch, (the open cell foam spacer at the top of the wing does not help as it can hold water.)
2) Bottom of the wings near the door pillar were the wing bolts to the top of the sills. (design fault with arch liner meens rubbish gets in next to the strut and ends up in that corner.)
3) Top of the sill were it bolts to the bottom of the wing (same location as above but the sill top this time) As the robots at the factory would grip this location when moving the shell and could crack the paint. (effects early cars)
4) Bottom of the boot badge hole. Water sits in this location)
5) Jacking points on the sills, The sealent can be damaged when lifted on a wheels free ramp at the dealers or garage.
6) 18" Alloy wheel corrosion due to the polished design (corrosion known as white worm)
7) Wheel VW badges and also the earlier smooth boot VW badge also suffer white worm.
Offline tech1889
  • Mk2 GTI FTW !!
Re: is this rust?
« Reply #3 on: 15 August 2011, 15:11 »
As rhyso said defo rust and 'try' and get VW to sort it if not it wont be expensive that little patch for a bodyshop  :smiley:
Offline mrDMH
Re: is this rust?
« Reply #4 on: 15 August 2011, 15:28 »
THIS IS SPARTA RUST
Offline Jimp
Re: is this rust?
« Reply #5 on: 15 August 2011, 15:55 »
THIS IS SPARTA RUST
:grin: This may become a regular saying in the mk5 section  :lipsrsealed:
Not low enough mk5
Not on the road enough mk3
Offline _Adam_
Re: is this rust?
« Reply #6 on: 15 August 2011, 15:56 »
i will try to get down there this week then, didnt know it was 12 years :shocked:
THIS IS SPARTA RUST
lol very imformative, thank you :grin:
Offline mrDMH
Re: is this rust?
« Reply #7 on: 15 August 2011, 17:50 »
Haha, sorry Adam, everyone had covered the informative stuff, so I thought I'd ease the pain with some comedy!
Offline Snoopy
  • Geoff.
Re: is this rust?
« Reply #8 on: 15 August 2011, 17:55 »
If your car is an early one its a known issue your dealer should be able to find the TPI on it.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline _Adam_
Re: is this rust?
« Reply #9 on: 16 August 2011, 09:11 »
53 plate lol
think mine is the grand daddy of mk5's :cry:
