Author Topic: steering lock removal  (Read 3170 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 14 August 2011, 17:28 »
any ideas any 1? ive ended up now with columb off . theres a bearing around the top of the steering lock  then a spring  how do i get it off
Offline kuvalee
  • Approved vag painter since 1999
Re: steering lock removal
« Reply #1 on: 14 August 2011, 20:11 »
STOP THIEF!!
Offline SoundillusioN
« Reply #2 on: 15 August 2011, 09:44 »
Any good to you?
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=598101
Offline matping
« Reply #3 on: 15 August 2011, 20:05 »
yes tried the mk1 forum yesterday ! im going for option 2 and getting anouther column 1 thats allready fitted with a steering lock
« Reply #4 on: 16 August 2011, 10:03 »
Ah OK.... Probably the easiest option.
Offline matping
« Reply #5 on: 29 August 2011, 19:06 »
i hate giving up on things tho  so i attacked it again today i put the column up side down on a block of wood so i wouldent damage the end the steering wheel goes on and tap'd the end off with a bolster and hammer it was on solid and took some doing !   it all came off then put the new lock on  and cleaned the end up with the linisher where id been hitting it with the bolster ! its all good !! :smug:
« Reply #6 on: 01 September 2011, 12:33 »
nice one!.. you should do a pictorial guide!  :grin:
