Author Topic: Quick help please!! Only have an hour or so to finish the job and I'm stuck!!  (Read 1694 times)
Offline drivebycar
Hi,
I am swapping mk4 calipers onto my mk2 gti. Have got to the stage where I need to disconnect the hardline brake line from the brake hose that connects to the calipers as I am fitting the conversion hoses. I cant seem to disconnect the hard line from the hose, I am rounding off the 11mm bolt and think I'm about to snap the copper pipe! Is there a trick to this?
Thanks!
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline tech1889
  • Mk2 GTI FTW !!
are you using brake pipe spanners ??
Offline drivebycar
No? Just normal spammers. What's the difference?
silky16v
Need to use proper pipe spanners like thishttp://www.ebay.co.uk/itm/6-Piece-Flare-Nut-Brake-Pipe-Spanner-Wrench-Set-/250708317199?pt=UK_Hand_Tools_Equipment&hash=item3a5f61540f#ht_2845wt_989
Or use a set of mole grips and clamp it real tight ( this will however round the nut off)
Offline drivebycar
I think I might have rounded it off too much now. Can I blowtorch then use mole grips?
silky16v
Just mole grips and try and get a really good hold of it
Offline drivebycar
I've bought a brake pipe spanner and a blow torch. So not taking any prisoners! Should be able to get it done :)
