Author Topic: Mk4 1.8gti Engine stops after 3 miles!.  (Read 3674 times)
Re: Mk4 1.8gti Engine stops after 3 miles!.
« Reply #10 on: 22 August 2011, 23:57 »
Looks like a good result then :afro:
Offline Toby
  • Car - less
« Reply #11 on: 23 August 2011, 12:13 »
Glad it's sorted!! I with every one was like you, giving a good explanation to there fault etc and therefore the right help is right there :)
Currently down under
Offline vwprime
« Reply #12 on: 08 February 2012, 23:03 »
The same code has just come up on my TT, with the same symptoms. Thankfully the car is in a nice dry place so can work on it a little bit better, compared to the drive way.
Looking around on the Forums trying to find out info about this it’s been alarming at how many people have reported the same problem around the same time. Mostly start from August 2011 up until now. Must be a come thing to start braking around that time of year.
TRANSFORM, & ROLL OUT!
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #13 on: 08 February 2012, 23:42 »
funny enough i had it cut out on me a few times for no reason and no fault codes the last time it cut out it wouldnt start then it just started again scanned it and no faults first two times it cut out on a motorway and starts again like a cough if you get me maybe mine is on its way out too
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
