Author Topic: tightening help  (Read 831 times)
Offline stainesy
tightening help
« on: 14 August 2011, 11:06 »
Going to change my drive shaft today but reading the haynes manual it says about 3 stages of tightening the hub nut. I aint got a torque wrench so do I realy need to use one? Can I just tighten up all the bolts without one?
Offline dansmk3
  • FULL TIME JUNGLIST
Re: tightening help
« Reply #1 on: 14 August 2011, 11:10 »
if your good with gaugeing strength here is a way of working out torque without a wrench.
if you need to tighten 10Nm - this works out as the pulling force of pulling 1Kg over a meter
40Nm = 4Kg over a meter, and when it starts to get harder your at the torque.
this is not advised but good if you dont have a torque wrench!
or get yourself down to argos i picked up a torque wrench for £20 FTW
Offline stainesy
Re: tightening help
« Reply #2 on: 14 August 2011, 11:20 »
Also what the hell does angle tighten mean?
Offline dansmk3
Re: tightening help
« Reply #3 on: 14 August 2011, 11:23 »
angle is as it says mate.
say you put the socket on and as you look at it it is poiting at 12o'clock, if you angle tighten 90degs then it will be pointing at 3o'clock
does that help? sounds right in my head lol
Offline danny_p
Re: tightening help
« Reply #4 on: 14 August 2011, 11:25 »
it's where you turn the nut / bolt X degrees
eg you may see on a cyl head   40NM   + 90deg + 90 deg
that means torque with a torque wrench to 40 newtom meters, then with a BAR turn it another 1/4 of a turn then another 1/4 of a turn     ( it's a way of putting a bolt under a set tension or strech as sometimes it may require diffrent quantites of torque  but a turn is allways a set distance due to the threads
all the VW's have gone bar 1.
Offline AudiA8Quattro
Re: tightening help
« Reply #5 on: 14 August 2011, 19:09 »
Buy a torque wrench, don't do the hub nut without it.
