Author Topic: jacking points  (Read 790 times)
Offline birch
jacking points
« on: 14 August 2011, 10:12 »
im struggling to be sure exactly where the jacking points are on my 1993 2e 8v gti, there are 4 points on the sills to use the scissor jack that came with the car but i cant see any markings to show exactle where these reinforced points are and also i think there are 4 reinforced points under the car for a trolley jack, ive found the front two which are a little squashed but could someone tell me where to use the trolley jack at the rear and where the sill markings are too. thanks.
any other places to use a trolley jack would be appreciated too.
« Last Edit: 14 August 2011, 10:15 by birch »
Offline dan_apps
  • too low for british roads!
Re: jacking points
« Reply #1 on: 14 August 2011, 10:15 »
should have cut outs on the plastic sill covers, at the front and rear the reinforced bits are quite clear to see :undecided:
wouldnt go with a scissor jack though they are hideous and wreck sills. when i jack up the rear with my trolley i do it on the beam.
Offline birch
Re: jacking points
« Reply #2 on: 14 August 2011, 10:17 »
beam? are the rear trolley jack points raised like the front points?
Offline tweed
Re: jacking points
« Reply #3 on: 14 August 2011, 11:07 »
I jack the car on the middle of the rear beam and in the middle of the subframe  :wink:
