Author Topic: GTI fog light adapters wanted  (Read 1259 times)
Offline vw bob
« on: 13 August 2011, 18:53 »
Hi there in process of fitting GTD front bumper onto my car , does anybody know where can i get plugs for the foglights as the MK6 GT model runs HB4 plugs with 11 mm between pins and the GTD/GTI runs H8 with 6mm between pins . So on the lookout for HB4 male connectors and H8 female plugs . Any help would be appreciated.
Thanks in advance.
Offline Snoopy
  • Moderator
  • Geoff.
Re: GTI fog light adapters wanted
« Reply #1 on: 13 August 2011, 19:10 »
A TPS depo or your local VW dealer will be able to supply you with the plugs and repair wires with the crimps on the ends.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline vw bob
« Reply #2 on: 13 August 2011, 20:31 »
I would need part numbers if i go to VW dealers and i dont have any.
Offline dubber36
« Reply #3 on: 13 August 2011, 21:11 »
Just give them the reg number of a car that has front fogs.  :wink:
Offline SteveP
« Reply #4 on: 14 August 2011, 08:47 »
Connector plug is 3D0 941 165 A and the repair wires for this are 000 979 244 E.
