Author Topic: HELP WITH STEREO AND CENTRAL LOCKING!  (Read 963 times)
Offline tam
« on: 12 August 2011, 19:39 »
 hi there can anyone advice ( 1997 r reg golf gti, 8v, 2.0) about why stereo can  be cutting out all the time (which is very annoying) tryed different stereos, it will play normaly but after 5 10 min it will cut out, power still staying on, but radio or tape will be cut out (not playing )  and can anyone advice cental locking making hising long sound (  think there is leak from lock and not locking  rear passengers side door ,  :sad: :nerd: thanx
Offline javalin
Re: HELP WITH STEREO AND CENTRAL LOCKING!
« Reply #1 on: 13 August 2011, 09:17 »
>cental locking making hising long sound (think there is leak from lock and not locking rear passengers side door...)
yes - take the door trim off and replace the hose.  The central locking as you've probably guessed is pnumatic (air) powered.  After years of use the hoses can split.  See my blog as i've recently taken that door apart to solve a wiring issue.  http://javalins.wordpress.com
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline tam
« Reply #2 on: 13 August 2011, 19:31 »
thanx for ur message !  gonna try to do that!  i guess can buy new hose from ebay! :)
Offline tam
« Reply #3 on: 13 August 2011, 19:44 »
do u know what size pipe goes? thanx :smiley:
Offline javalin
« Reply #4 on: 13 August 2011, 21:10 »
VW only as far as I know....
Offline Seanl
« Reply #5 on: 13 August 2011, 21:55 »
3mm silicon hose from ebay is fine so I've read.
