Author Topic: mk2 8v high hydrocarbon  (Read 1697 times)
Offline rossbarry1
« on: 12 August 2011, 10:36 »
I have a mk2 8v with a tsr fast road can in it, it failed its mot yesterday on high hydrocarbons, 1575 and should be a Max of 1200, is there anyway of timing the engine up to reduce this? It am I going too have to swap the cam to standard to pass??? Thanks
Re: mk2 8v high hydrocarbon
« Reply #1 on: 12 August 2011, 13:24 »
Digi or k jet :undecided:
Offline rossbarry1
« Reply #2 on: 12 August 2011, 13:38 »
Digi
« Reply #3 on: 12 August 2011, 15:42 »
Might be a temp sender problem, the mixture is controlled by the ecu so no real way of adjusting it.
Offline Agreeable Slick
  • Unit
« Reply #4 on: 12 August 2011, 15:51 »
Do a filter change, get some fuel system cleaner through it and take it out for a good raggin before sending it in again.
Offline mwep201081
« Reply #5 on: 12 August 2011, 18:15 »
good service and a severe thrashing before retest usually works for me.....
Offline danny_p
« Reply #6 on: 13 August 2011, 19:14 »
oil change and a good ramping normaly sorts them
all the VW's have gone bar 1.
