Author Topic: v5 non runner?  (Read 1844 times)
Offline tonysgti
v5 non runner?
« on: 11 August 2011, 20:29 »
my friend has just purchased a golf v5. it is a non runner, its got petrol, got a spark(although looked alittle weak?) but wont run? just turns over? scanned the car and nothing is coming up? any ideas?
Offline Granta Gti
Re: v5 non runner?
« Reply #1 on: 11 August 2011, 21:01 »
Camshaft or crankshaft position sensors?
Re: v5 non runner?
« Reply #2 on: 11 August 2011, 21:21 »
So many things it could be but sounds sensor related
Offline tonysgti
Re: v5 non runner?
« Reply #3 on: 11 August 2011, 22:00 »
I though sensor but I have scanned it afew times? Nothing came up?
Offline tonysgti
Re: v5 non runner?
« Reply #4 on: 12 August 2011, 08:31 »
any ideas? as its been scanned i thought that would rule out sensors? dont fancy buying sensors for no reason due to money.
Offline robz
Re: v5 non runner?
« Reply #5 on: 12 August 2011, 09:17 »
Not up on your engine, but I'm sure sometimes the crank sensor doesn't ping codes? Maybe worth trying it!!
Coil pack too?
Offline vwblackmk4gti
Re: v5 non runner?
« Reply #6 on: 12 August 2011, 15:25 »
if you got spark and petrol, but no bang then you most probably got no compressor,
check the cylinders compression.
Offline Granta Gti
Re: v5 non runner?
« Reply #7 on: 12 August 2011, 15:48 »
I suppose the sensors would have thrown up a code, if no compression I think your next bet would be to check the timing ( do the V5s have chains or belts?) if it is belt driven and if nothing from that whip the head off.
Re: v5 non runner?
« Reply #8 on: 12 August 2011, 15:49 »
Chain driven :afro:
Also worth remembering early ones were noted for piston problems
« Last Edit: 12 August 2011, 15:58 by Wayne »
Offline Granta Gti
Re: v5 non runner?
« Reply #9 on: 12 August 2011, 15:55 »
Oh ha ha
