Author Topic: Joey Mod = Failed :(  (Read 3628 times)
Offline Bellend
Re: Joey Mod = Failed :(
« Reply #10 on: 11 August 2011, 11:06 »
Do they have Hella stamps?
Where all my moneys went.
Offline kempie
  • where would we be without duct tape?
« Reply #11 on: 11 August 2011, 11:16 »
dont think so :/ i'll have too look when i get home, why?
Offline Seanl
« Reply #12 on: 11 August 2011, 12:55 »
Yeah don't leave em in too long. I did, and the back has caved in, and I had to get my heat gun to melt and straighten out the brackets. Looks a right mess! :sick:
Offline trog_nfs
« Reply #13 on: 11 August 2011, 13:41 »
as in heating it to get the glass off the bloody unit :(
put it in the oven at 150 for 3mins, took out, burn hands, cut away as much as i could, bent loads of plastic, got annoyed cracked out the heat gun and nothing :(
150? I put mine in for 5-10 mins at 50 C, bit of leverage behind the glass and bobs your uncle
Offline Deano2711
  • 1992 VR6
« Reply #14 on: 11 August 2011, 13:49 »
I don't know why they need to go in the oven personally. I always just run a Stanley knife around the seal and then gently prise the glass away with a flat head screwdriver. Done this loads of times and Snifferdog can vouch for this as he watched me do his !!!!  Takes seconds and no damage, then just remove the old seal and alls done.
Offline mellow yellow
  • A Driffield Dubber!
« Reply #15 on: 11 August 2011, 15:04 »
i tried without heat but things started to crunch so i wacked them in the oven at 150 for 1 1/2 mins and they prised off no bother.
Offline Bellend
« Reply #16 on: 11 August 2011, 16:16 »
If they aren't Hella they may be pattern and can be an arse to split cause the glue is solid.
I've literally undone the clips and just pulled the glass off with my hands before.
Offline kempie
« Reply #17 on: 11 August 2011, 18:18 »
so they aint hella's so thats proberly not helping :(
just tryed again with the other light at 50 for 10mins and still f**k all
so anyone close by that i can annoy for some help please?
Offline dom
  • Back in a Mk4
« Reply #18 on: 11 August 2011, 18:31 »
I just use a hairdryer and stanley knife :wink:
Offline Deano2711
  • 1992 VR6
« Reply #19 on: 11 August 2011, 19:08 »
Don't you have a spare set of the dual chambers that you were prepared to Joey and then sell Dom ??  Maybe a quicker solution for the op  :wink:
