Author Topic: What is it?  (Read 9372 times)
Offline richandhazel
Re:What is it!
« Reply #10 on: 17 September 2003, 11:16 »
Hand brake doesn't lock off? do you mean its not releasing or not holding?
You'll need to replace the fuel filler pipe. Its a common problem as all the mud etc., sprays up from the rear wheel onto it causing it to rust through.
You can get replacement fuel filler pipes and if you look hard enough you'll come across the odd stainless one that Autocavan used to sell. Not aware of anyone that manufactures the stainless one anymore.
Re:What is it!
« Reply #11 on: 17 September 2003, 11:18 »
Seats bolster wear is common too. You'll have to keep your eyes open for a good set.
Does anyone know if its possible to buy the bolster 'foam' from VW and for that matter the cover?
Offline Justins145bhpMK1
Re:What is it!
« Reply #12 on: 17 September 2003, 11:24 »
Aaah the usual problems!!!!
You can get any of the seat bits from VW anymore, just have to hunt around and see what you can find!!!
Rich, what did you actually pay for that white mk1?? I reckon you may have had an even better bargain than I got with the Campaign.
Re:What is it!
« Reply #13 on: 17 September 2003, 11:35 »
I didn't pay anything.........just bought the guy a couple of beers.
He was going to scrap it........I just stepped in to prevent it going to the scrappy.
golfvr6
Re:What is it!
« Reply #14 on: 17 September 2003, 12:05 »
Nice one  ;D  Does the car run?
Re:What is it!
« Reply #15 on: 17 September 2003, 12:17 »
No, fuel pump is siezed. It turns over OK. Its been sat in a garage for 5 years. I only bought it for spares but have subsequently found that it is far too good to scrap.
Unfortunately I simply don't have any time to spend on it at the moment, so it will be mothballed for now. Its got that 4 into 2 exhaust manifold that I have been after for the cabrio so it was worth getting for that alone.
golfvr6
Re:What is it!
« Reply #16 on: 17 September 2003, 12:27 »
I know what ya mean, i don't even get enough time to work on my own car, let alone any project  :'(
Offline AdamB
  • The Perfect Storm
Re:What is it!
« Reply #17 on: 17 September 2003, 12:37 »
The cabrio sounds fantatsic, what does it run like with the 2.0l in it. I look forward to seeing it a few shows next year then
I don't own this anymore - I just can't be arsed to change the picture
Offline danhock
Re:What is it!
« Reply #18 on: 17 September 2003, 14:32 »
Its pretty quick... takes no time to get to the rev limiter ;D
Im used to a Nissan 300zx though so not sure!
Steerings pretty heavy though...
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
Offline AdamB
  • The Perfect Storm
Re:What is it!
« Reply #19 on: 17 September 2003, 14:43 »
Quote
plenty of feedback then - you should try 205 section tyres then - forearms like Popeye :)
